Thread Tools
Old 06-10-2008   #1
Speed Camera Tester
ilsonemo's Avatar
ilsonemo has donated!
hey thinking of buying a brava
hey my for escort went tits up today and im now looking for a new car, i have been offered a fiat brava, 1.2 ltr 16v, 5 door,
-MOT UNTIL APRIL 2009
-ELECTRIC WINDOWS
-POWER STEERING
-78000 miles
for £550 do u think thats a good deal ? and is there any nown problems that bravas get ?
Quote Originally Posted by Charnwood Fox View Post
Only if you've got a trump-shuffler standing behind you when you are bent over the engine bay.
ilsonemo is offline Reply With Quote Quote
Old 06-10-2008   #2
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: hey thinking of buying a brava
They're typically pretty reliable cars. Most important thing with a car of that age/mileage is does it drive well? If it does then you can worry about things like worn suspension arms, worn clutch, headgasket... just the usual bits to check really... rust or signs of repairs.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 07-10-2008   #3
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
head gasket is the biggest issue on the 1.2. they also suffer from gearbox differential failure, and an erratic idle is also common. check for these things.
there should be 1 red key and 2 blue keys.
there are also a few faults common to all models., such as rear wash failure, rear wiper failure, basically anything electrical should be checked. make sure there is no sign of a sunroof leak (mouldy/stained roof lining).
any faults you find can be fixed, but you can use them to get the price down.
£550 isnt a bad price if everything works and it is in good condition, but i'm sure you could haggle down to £500.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 08-10-2008   #4
Speed Camera Tester
ilsonemo's Avatar
hey went and had a look at that brava, its really nice just one problem though, when your in 3rd and 4th gear under load it judders, what do u suggest that is ? cheers
just thought id add its had the clutch done recently and new break pipes
Old 08-10-2008   #5
Trader Rating: 1
JoskeJTD has donated!
Could be a worn clutch if it judders under power. Known as clutch slip. With that amount of miles and no clutch change i would expect the clutch to be well used and past it.
Also at that mileage I think its best to have the cambelt and aux belt changed if its not been recently done, as its at the mileage it should go.
JoskeJTD is offline Reply With Quote Quote
Old 08-10-2008   #6
Speed Camera Tester
ilsonemo's Avatar
the clutch has been replaced recenly, do u think it could be spark plugs and leads ?
Old 09-10-2008   #7
jug
jug's Avatar
Trader Rating: 1
jug has donated!
its hard to say. if its misfiring under load then on the 1.2 it is often the leads, or a head gasket failure. it could also be a botched clutch change, or maybe the flywheel was buggered and they didnt nother resurfacing it during the clutch change.
Thread Tools
(G) Thinking of buying a GP 1.9 PeteyPye Grande Punto 39 21-08-2008 12:24
(G) Thinking on buying an X1/9 yellowmitch X1/9 4 04-03-2008 15:52
(G) Thinking of buying one shaun X1/9 11 08-07-2006 18:43
(G) Thinking about buying one Boudreaux Barchetta 86 10-02-2006 11:56
Im thinking of buying this....... CruiseBabeGem Lets Talk FIAT 21 01-06-2005 21:21
