Thread Tools
Old 24-09-2008   #1
erratic idle when starting w reg bravo
when it is started it idles to 3k rpm + .
its the 1.2 16v with 50k odd on the clock.
what could this be & how can i sort it?
kgsric is offline Reply With Quote Quote
Old 24-09-2008   #2
South Sandwich Islands
Re: erratic idle when starting w reg bravo
icv probably. I'm sure someone will probably tell you more though
Alfa Romeo 147 1.9jtdm Lusso
Kawasaki ZX600E7
ZZR6 is offline Reply With Quote Quote
Old 25-09-2008   #3
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
check for a vacuum leak (cracked or split on any of the pipework before the throttlebody.
try cleaning inside the throttlebody.
try adding washers between the idle speed controller and the throttlebody. for some reason this trick usually works.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Thread Tools
(G) Bravo engine idle erratic help!! fishing50mrh Bravo / Brava 8 20-04-2007 09:32
(G) 55 sx 1.1 idle is erratic Bigbadtez Punto (Mk1) 4 28-08-2006 19:22
(T) Erratic idle speed davet Punto (Mk2/2b) 0 19-03-2005 17:39
(T) Erratic Idle speed rmcsherry Punto (Mk2/2b) 7 31-01-2005 12:26
(T) Erratic Idle Jonah431 Bravo / Brava 2 15-08-2003 15:29
