K kgsric New member Joined Sep 24, 2008 Messages 1 Points 1 Sep 24, 2008 #1 when it is started it idles to 3k rpm + :bang:. its the 1.2 16v with 50k odd on the clock. what could this be & how can i sort it? Thanks Last edited: Sep 24, 2008
ZZR6 New member Joined Jan 9, 2007 Messages 248 Points 49 Sep 24, 2008 #2 icv probably. I'm sure someone will probably tell you more though
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,763 Location Durham Sep 25, 2008 #3 check for a vacuum leak (cracked or split on any of the pipework before the throttlebody. try cleaning inside the throttlebody. try adding washers between the idle speed controller and the throttlebody. for some reason this trick usually works.
