Thrisey
Well it has done so well for 12 months now, after the head gasket but we are off again now, it has started doing a jerky thing seems to happen when it is under presure, as in pulling away from a junction and you need some gas, same going up a hill, foot down and it jerks occasionally when overtaking as well but not often as you have wound it up by the time you pass anyway.
it does it hot or cold doesn't matter (I seem to think it is slightly worse in the cold) once the revs have picked up it setals again and is ok, expressway driving fine. Starts fine, ticks over fine. had new plugs and leads 4 months back no injector light, doesn't feel or sound like a missfire, if you where to go back to the old days I would guess at a carb problem something like a semi blocked air way or jet, it is not a flat spot it is actual jerks, feels like it wants to get away but can't you have to bring your foot back off the throtal then is will setal.
I wondered if it was lambda probe giving up after all the water that went through the exhaust last year, but to be truthful I would have thought it would have shown up a lot earlier than this, the car does over 300 miles a week 90% of it expressway so it is above 70mph, any ideas?
Chris
Oh yes it is a 1999; 1.2cc; 16valve; 1,115000miles standard engine
Chris
