Hi all, Thanks for the reply's...
its nearly done, investigation showed the bottom end failed completely
Photos of cylinder 5, 5, 4, 3, 2, 1 shells
No: 5.
No 5 again.
No: 4.
No 3.
No 2.
No 1.
the engines been swapped over now and the car is running, but there are still some small issues to resolve
work that's been done :
recon engine
new water pump
new belts, cam belt, ancelry belts, and tentuners
nearly new clutch put on it
new thrust bearing
new clutch slave cylinder as it was leaking
new plugs
air filter
new oil and new gear box oil
there was a split pipe to the vis system that was changed
The car is running now but he isnt 100% happey with it and wants to solve the remaining 2 issues
1) the VIS system it's pulsing which is making the diaphragm actuator arm knock, it doesn't do it all the time it's intermittent and only happens while the engine is tick over,
2)another annoying issue is a buzzing throttle servo motor (this is that buzzing issue i talked about, he had 2 VIS fiat blocks up there, non of them buzz like this)
so any advice on the last two issues would be great
essentially it will step back up a gear when i get paid this month to finish off the work
