Fiat
ePer systems tells me its a 1Q-Marea BZ Gamma 1999-2002.
(All I
know is It's a 1999 (December) 1.6sx 100.)
I have
multiecuscan and it managed to get me an ABS fault code from one of the 3 pin connectors, nothing from the other 3 pin connector
also on the fuse box. (I don't know why there's two connectors, one engine, one abs maybe?)
Fiat dealership said it's too old, not a chance, took it to 3 garages with different diagnostics, ranging from a flash tablet to
a multi thousand pound system, nothing worked.
re: If your upper intake is metal
Could you elaborate on that please?, I'm no mechanic, just flailing about try to sort this for my son...
It's had a new official coil pack/plugs etc. The injector light has been getting more frequent for about a year and it seems to be running on three almost all the time now regardless of the light. It *seems* ok when first pulling off just for 30 secs. (not long enough to be temp sensor related methinks...?)
I measured the resistances of the injectors and 3 are 14.3 ohms or thereabouts, the last one is inconsistent, seems to be 22-27.
It's at the end not sure if that's 1 or 4 but it looks like a suspect to me.
For amusement, I rang Fiat for a price on a new injector (Part 71718998) - 373 quid please.
As ever, any thoughts appreciated.
Steve
