Old 31-08-2008   #1
Xen has donated!
Headgasket or any other possible cause?
My gfs dad has just bought a '97 1.4 bravo. It wasn't till he was driving it home he found an overheating problem so called me over.
Car was cold when i got there, but i noticed the coolant bottle was wet as if coolant had poured out of the cap. Had a look in and there was barely any coolant left in there. Checked oil - good level, no mayo anywhere and fairly new from the look and feel of it.
Started it up and pulled the oil breather pipe off - no noticable air movement. Had the coolant cap off and as it came up to temp, thermostat opened and the coolant began to bubble. As i revved the engine, the coolant would bubble more vigorusly. Also a fair bit of smoke/steam from the exhaust while revving. It still drives really well, plently of pull. Rad fan never comes on, despite the temp needle sky rocketting!
To me this clearly says headgasket, but any other possible causes before i give him the bad news? also anyone done a 1.4 HG? how much in parts and how long to do? difficult? does the head need to be fully stripped to be skimmed for these engines? (i've done the 1.2 8v HGs before.)
Xen is offline Reply With Quote Quote
Old 02-09-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Headgasket or any other possible cause?
its a bit early to confirm head gasket failure, it could also be water pump or a blockage or a rotten rad or even an extreme example of the very common oil circulation problem.
the fan issue is usually a rusty relay connection, the relay is on front of battery tray.
first thing to do is a compression test to decide if the head gasket has gone.
skimming the head means the cam and valves need to come out. if the cam lobes look worn (especially over cylinder1) then it is suffering from the oil circulation problem and you need to clean inside the oil bar (sits over cam) by bathing it in something like petrol or paraffin overnight.
Thanks Xen thanked for this post
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 16-09-2008   #3
Xen has donated!
OK, tested and it isn't headgasket.
Tested thermostat while it was off, opening just before boiling point (sorry, didn't have a thermometer for a more accurate result but it DOES open.)
Radiators gone to be checked for blockages and/or leaks now.
Any other tests i should try?
EDIT: The cams appear to be ok btw.
Old 16-09-2008   #4
jug
jug's Avatar
Trader Rating: 1
jug has donated!
maybe it isnt overheating and the temp gauge is telling fibs. its common on bravos. a good thump above the needle can often fix it.
Old 16-09-2008   #5
Xen has donated!
Lol i wish it was that simple
The coolant starts bubbling in the reservoir as the engine warms, somethings broken somewhere
Old 16-09-2008   #6
Ireland
if the coolant is bubbling and pressurising the system, and there is steam in the exhaust, its time to get the torque wrench out.. you could do a CO test on the expansion tank to be sure though.
Faster Horses, Younger Women, Older Whiskey and More Money.
'01 Bravo JTD100, '98 Coupe 20VT
stylers is offline Reply With Quote Quote
Old 24-09-2008   #7
Xen has donated!
Right, well we removed the rad and had it checked... no blockages and no leaks. Although it didn't seem like HG, we removed the head and checked the gasket and surfaces - no sign of HG failure, new HG set and bolts were used to reassemble.
Still the same problem ... when the engine comes up to temp, coolant floods out of the reservoir. Any ideas?
Old 24-09-2008   #8
Xen has donated!
Just left it idling for 5 min... after 5 min, temp had just reached the red mark.
Fan never came on, but i think thats because the radiator wasn't actually that hot (and IIRC the sensor for the rad fan is on the rad.)
Top of the rad was a little warm (but that could have just been the exhaust manifold behind it) and the bottom of the rad was stone cold. Heater gave out no heat either.
Pipe to the top of the reservoir was roasting hot, pipe from the bottom was cold.
Any suggestions from these symptoms? its driving me nuts!
Old 24-09-2008   #9
Here to help
bridges's Avatar
bridges has donated!
Had you not said you'd checked it... i'd swear it was a thermostat
Ink Black Coupe,
Koni susp' kit, Strut/Subframe bars. Camber bolts, 3g Discs, Yellow pads. Ram air, S.I.P, FMIC, Superspool turbo, Aquamist, Full S/S decat exhaust. Hid's, Le kit and Tan leather.
Alfa 156 16v Jtd-m Ti 150bhp
http://i54.photobucket.com/albums/g1...2006/alfa1.jpg
bridges is offline Reply With Quote Quote
Old 24-09-2008   #10
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
Have you looked at the water pump at all? I know jug suggested it.
To be honest I feel like asking if the pipes to the radiator are the wrong way round but that would be silly.
Adrian Bravo is offline Reply With Quote Quote
Old 24-09-2008   #11
Xen has donated!
Quote Originally Posted by bridges View Post
Thats all I can think of. It did open in a boiling pan, but whether its opening too late may be the cause.
I didnt remove the water pump but checked that there was no play and that it span freely, which it did. How can i check that its actually pumping the coolant?
Pipes are deffo the right way round they would only physically fit one way
Old 24-09-2008   #12
Ireland
you said there was steam from the exhaust ?. Was this while driving with engine fully warmed up ?. If you're sure HG was OK, and the stat is opening in boiling water, the only other thing would be the water pump impeller spinning freely on the shaft, i.e not pumping at all. If the stat is opening then the rad should get warm as water circulates.
Old 25-09-2008   #13
Xen has donated!
Quote Originally Posted by stylers View Post
To be honest, when i was running the car this afternoon, the exhaust seemed fine - that could have been because the car hadn't been run in a while when i first went to see the car.
I took the head and the old gasket to my local garage to ask for a second opinion from the mechanic who MOT's my cars etc, and he said from what he could see there was no evidance at all on either the head or the old gasket of gasket failure. The only thing that was a bit odd was that the valves on number 4 cylinder looked more sooty than the other three, but only slightly.
I can understand now why the waterpump could be a possible cause - i suppose if the coolant isnt being circulated, the coolant in the block is just going to get very hot and expand too much, hence causing the overpressurisation.
If the hose from the thermostat to the top of the reservior is getting so hot, that proves the thermostat must be opening, right? so i can rule out thermostat all together? therefore it must be waterpump?
Old 25-09-2008   #14
jug
jug's Avatar
Trader Rating: 1
jug has donated!
that is also my suggestion. the water pump needs to be removed and carefully chacked.
Old 25-09-2008   #15
Xen has donated!
Well the water pump looks fine - removed and the impellor is fixed firmly to the shaft. I can confirm water isn't circulating though - the coolant that came out when i removed the pump was orangey/pink like the original stuff, but the new stuff i'd put in was blue.
(G) headgasket needspeed Cinquecento / Seicento 6 10-02-2008 00:00
(T) headgasket Gorman1981 Punto (Mk2/2b) 4 01-09-2006 20:27
(T) Headgasket? Zorro Punto (Mk2/2b) 1 05-05-2006 17:06
(G) headgasket skinnyvinny Cinquecento / Seicento 15 19-03-2006 20:31
(T) headgasket philbo Cinquecento / Seicento 12 05-10-2005 15:54
