how could the bio-diesel (salad-oil) ruin the old pump in the first place? Someone said something about the lubricating properties were not sufficient for this type of pump? Or is it more agressive and attack seals? (No, not clubbing them!) And could the pump (or seals therein) be damaged just standing around with a Redex/salad-oil solution in it?
the greatly increased viscosity puts the pump under more pressure, reducing the life of the bearing and seals. similarly it can damage the injectors. you need to keep the viscosity down by using lighter oils (rape seed) and a lighter mix (use 50% diesel). steps such as this can greatly increase the life of the fuel system components.
