hi i bought a fiat bravo 1.4 sx a couple of months ago and have been having idle problems (sounds as tho its missing or the mixtures wrong) with it and also a lack of power i cured the lack of power with a new cam shaft the old one was extremely warn and a fuel filter but the idle problem still persists i'v changed the icv ,i'v cleaned the throttle and butterfly valve and conections ,i'v changed the ht leads the spark plugs,to no avail i then noticed a split pipe from the rocker cover to the top of the throttle body i changed that and there was a slight difference in power and idle. but still revving between 800 and 1500 (before it was 800-2000) so i dissconected the battery for an hour reconnected it left the ignition on for 90 seconds and of started the car up and took it out for a drive about 30seconds after ,the car started to loose power for no reason in short bursts pulled over and the car was almost stalling going write down to 500 and then kicking back in to over 3000 revs doing this very quickly. i manged to turn it around but it kept stalling with the clutch pressed so couldnt change gear or it would stall i managed to get it back home but now i cant take my car out because if you release the throttle whilst foot on the clutch it stalls (i think the resistance from the cluth is making it stall as when on idle it is extremly close to stalling itself).
can any one help me please :worship:
