Hi all,
I have one or two new problems for my little Fiat 1.9 TD100SX
While looking for a parking spot at the local shops, I was crawling along in 1st when the engine started to splutter as if it was going to stall. With a bit more revs it would jolt like bunnyhopping, so I stopped the car. It then chucked out a load of white smoke from the back, so I turned it off for a while.
I checked the oil, water, looked for leaks etc (about as much as I know, or could do at Tesco's) and all looked ok - aside from the water level being low. So I took it for a drive home and topped up the water and it seemed ok until I had to use it to get to work.
I've driven it quite a bit more, so should have some useful points for diagnostics now.
It only seems to do it when crawing along, say below 40. When it starts to splutter, if I give it some revs it keeps it going and also, I can stop it doing it if I drive home one gear too low, above 2500rpm.
At all times it feels like the car is fighting against something. Resistance or drag or something. It doesn't really seem down on power much and will hit 60 in roughly the same time (maybe slower, hard to tell).
Also and this might be my imagination or because I was actually listening with the windows down but I can hear a fast clicking sound above 3000rpm.
Once it starts, it will splutter and jolt for however long you let it. I'm unsure if it would eventually stall but I do know that once you give it some revs, it will chuck out one hell of a lot of smoke (pale, not pure white but not black that's for sure).
I do not know if this is related but thought I had better list it anyway:
I thought the car was losing water as well. I topped it up to the max line and drove 18 miles to work. Once there I checked it again and it was a good inch below min.
I left the car for 8+ hours at work and went out to top up the water. Upon loosening the cap it made a hiss/pressure release noise and the water level went back up to max level. Is that normal?? :S
Thanks for any advice you can offer,
Lee
P.S I've checked the oil and it looks ok, not milky or anything.
The temperature remains fine at all times and it doesn't seem to be losing water aisde from that pressure drop problem listed above.
Lee
