General turning right
Savage
Member
Royal leamington spa, mid
Right i need some help i am in two minds. I had my fronmt discs and pads changed recently and ever since whenever i turn right i get a squeeking coming from the front.
I am having the cambelt and ball joints done today but if it isn't the ball joint there is no point having it done.
Any ideas of what it can be
in that case i would check that both front brakes are not seizing. jack it up, then check both wheels spin freely, then pump the brake pedal hard a few times, then again check both front wheels spin freely. if they dont you have a seizing brake, which can usually be sorted out with a strip down, clean and greasing.
