im Axle Specialists
Old 02-08-2008   #1
Brooksy has donated!
Part Prices
how much should i be paying for 2 driveshafts and for a driver side upper suspension arm with spring?
Brooksy is offline Reply With Quote Quote
Old 04-08-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Part Prices
at a scrapyard driveshafts are usually 20 each if you remove them yourself.
you dont have upper arms, your suspension is only single wishbone.
or do you mean the strut (spring and damper as a whole ready to fit)? i have never bought one from a scrapyard so tbh i dont know, but it cant be much if you remove it yourself. i would always replace both sides, taking both from the same donor car.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 04-08-2008   #3
Re: Part Prices
ok is there any way i can check that the driveshafts are in working order and not broke in any way?yeah i did mean the spring part i think i will just get new ones all round instead and get it lowered
Old 04-08-2008   #4
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Part Prices
you can check the CV joint for play (hold shaft at either side of joint and then wiggle) but it isnt always easy to tell. trying to see if it is slightly bent is impossible without the correct tools.
(T) prices? RazmaGT Punto (Mk2/2b) 0 03-06-2008 17:03
(G) Part Prices : Interior YeTeP Punto (Mk2/2b) 6 18-03-2007 10:07
(G) Second hand mk1 uno part prices????? gtirx2 Uno 2 08-12-2006 22:18
(G) Crazy Fiat Part Prices Liam Cinquecento / Seicento 28 22-04-2006 15:49
(G) Prices.... MiniG Stilo 3 24-03-2004 03:02
