General Part Prices
General Part Prices
at a scrapyard driveshafts are usually £20 each if you remove them yourself.
you dont have upper arms, your suspension is only single wishbone.
or do you mean the strut (spring and damper as a whole ready to fit)? i have never bought one from a scrapyard so tbh i dont know, but it cant be much if you remove it yourself. i would always replace both sides, taking both from the same donor car.
you can check the CV joint for play (hold shaft at either side of joint and then wiggle) but it isnt always easy to tell. trying to see if it is slightly bent is impossible without the correct tools.
