[email protected]
- Jul 21, 2008
- 3
- 2
Bravo '51 radiator fan on all the time. Disconnected earth to stop this. Previously fan not kicking in at all and replaced the sensor unit, thermostat and water pump. Then connected directly to the battery and it worked. But now on all the time. Is this a prob with the ECU only? (fan cut-off function?). Previously had a front impact and may have shorted switch function on ECU - is that feasable? Am located Bedworth (CV12) Any one recommend a garage if all else fails.
