Technical front shocks
Chesterfield
the drivers front shocker decided to give in on the way back from sheff transport show on sunday. started hearing a knock on the way there but thought it was an exhaust mounting or something... on further inspection its the shocker.. got an advisory for it on the last MOT but i totally forgot about it. untill now!
went to parts place today and got two new ones (i know its best to swap them in pairs, handling n all that....)
thing is... parts place didnt have any of them dust protector thingie ma bobs.
bascially what i wanna know is... would it be ok to reuse the ones that are on the car now? like clean em up and that and use em on the new shocks?
also im gonna need spring compressors arent i?
and i gotta do it all on my own cos my parents went away for the week today so no dad to help me :eek:
yes you can re-use the dust covers.
you'll defo need compressors.
good luck kay. i'd have the top nut loosened at a garage before you start, it makes life so much easier.
Is it lowered? If so, you may not need the compressors. If not - you need them. Agree with having your nuts loosened at a garage first.
Soak all the bolts and nuts in oil before you do the job. You'll need a smooth bar to knock the bolts out that hold the strut to the hub carrier.
Remember when taking out the 13mm bolts holding the top mount to the frame to undo it a few turns, squirt in some oil then wind it back tight again. In out in out as you undo it so you don't snap a rusted bolt.
If your dad is only away for a week is it not worth waiting for the weekend? the springs are not the best of things to do on your own for the first time with no help/guidance if something goes pear shaped with the compressors then you can do some serious to yourself and your property.
Just make sure your fingers are never between the coils. Use a minimum of 3 compressors, and use the safety locks. Tighten them in order and watch that the spring is being compressed straight.
I've done quite a few now and haven't had a problem by following the above.
I'm with Hellcat on the the 3 spring compressors route. On previous Fiats I've only needed 2. But the Bravo front springs need a lot more compression, and are under quite a load, even uncompressed on a fully open shock.
The top nut can be an arse. So I'd advise getting this loosened before, or undoing this a little, whilst in situ on the car.
theres not really any one around to give me a hand in the day, all my male mates work :(
the nuts on the hub arent a problem, ive had them off countless times from driveshaft troubles n that, its just the top strut bolts im worried about. would it be worth giving them a good going over with plus gas and leaving em for an hour or so and then try?
oh and the car is lowered, so the bolts will have to been undone at some point, so that might make it a little easier, they wont be as seized as a car thats never been touched
thats the ones we're on about. defo loosen them on the car first, using an offset ring spanner and a hex bit in a 1/2" drive ratchet. if you cant do it like that on the car, then you definately cant do it off the car either.
it always helps.
Lowered... Easy!
The 3x 13mm bolts holding the top mount to the top frame rails shouldn't be an issue. Crack them loose, squirt oil under them, give them a few mins then wind them back on and off. I wouldn't put a torch on them given they're on painted surfaces.
Edit.. ah you meant the big ones. Always worth going to a garage and asking them to put the windy gun on it to loosen them.
