Hi, just wondering if you know of anywhere online that sells the cv joint kit for the inner side of the nearside driveshaft, the side that goes into the gearbox. If it isnt available would a driveshaft from a 2001 80sx fit straight on? Thanks
you have an 80sx, so a shaft from another 80sx will fit.
if you only need the rubber boot then any motorfactor can get one cehaply. if you need the actual joint then i'm not sure if a motorfactor will be able to get one, i've always took the scrapyard option.
Thanks, i thought as much. It is definately the joint, as ive had a wiggle around down there and it definately has a small amount of play in it on the engine side. i'll have to source one from somewhere then.
