HI
I've got a Bravo GT Turbo Diesel.
I have a problem with my water gauge.
Nomaly when the engine has his operating temperature the needle of the
gauge is in the middle.
My instrument goes up to the first lower dashes and some times it is bouncing around.It goes up and down.
The Fan is operatin right, thats not the problem only the right indication of water temp.
I changed the temp. probe.No help.
Messured the wire.Wire is fine.
Fiat told me that the problem comes from the whole instrument Unit.
[V]
I think it is only a tiny thing.
May be some had the same problem a solved it.
Thnak you
René
[V]
Thnak you
René
