typically my owner's manual for my Fiat Brava 100 HSX (99) has gone walk abouts. Therefore, can someone tell me what type of steering fluid I need to top it up as it's low??????!!!!
you use ATF DEXRON II same as most cars. its the same fluid used in auto transmissions. its a sae 10w spec fluid. just make sure you get a bttle that says ATF DEXRON II and you'll be fine.
