Technical indicator relay
Oldham, manchester
so i take out my centre console and instrument panel as it's going to the bodyshop to get sprayed, then i realise my indicators aren't working! is the relay for the indicators on the hazard switch? as that is also at the body shop!and what will happen if i get pulled over by the police for not having any indicators that work
disconnecting the hazard switch does disable the indicators, it isnt the main indicator relay (thats on the underside of the steering column) but disconnecting the hazard switch breaks the circuit.
you can insert some wire into the connector to get your indicators working, but its importnant that you inset the wires in the correct slits on the connector, and unfortunately i dont have my wiring diagrams (or even adobe reader) today so i cant tell you which wire colours to connect.
