Re: My Bravo 1.4SX (New Front Wing)
The WIPAC was too big 9.5cm ill have to keep looking, may have found a cheap cluster though.
i did that too, it looks a lot betterTonight im painting the edge of the lens where mould builds up on the inside.
It does At first i was just going to paint the inside of that lip black but then decided to do the outside too.I did that too, it looks a lot better
use 10w40 semi-synthetic.
5w40 is thinner when cold and the same viscosity when warm. there is no benefit to having lower viscosity when cold, it will drop the oil pressure making circulation to the cam even worse when the engine is cold. the first few mins of cold running are critical so you really dont want to use the wrong oil.
Small update im fitting it to my car tomorrow if the weather is ok along with a load of other stuff going on.Besides that it looks very good, any pics with it fitted on your car?
