and please....take a look at a connecter on a 1.4 and a 1.6...ull see they are the same.
you seriously underestimate me if you think i did not compare the connectors before my first post.
bridges said:
Jug, could this be possible.
no mate, he's talking crap, as i'm about to demonstrate.
shaun i'm currently sat in a mcdonalds carpark because i did not have time to reply at work, that is how much this thread has wound me up. since you seem so keen for me to make you look like and idiot, allow me to oblige.
there is a very long list of obvious differences that would mean you could not simply plug the 1.4 loom on to the 1.6 engine, its common sense to anyone who understands the basics of engine management. lets take one prime example, the difference between a single point injection engine and a multipoint injection engine. the 1.4 loom has 1 connector for its 1 injector, the 1.6 engine has 4 injectors each with their own connector, explain how you connected the 1.6 injectors to that single connector please.
actually, they say a picture paints a thousand words, to same we writing it all out i've attached 6 pics to this post showing the first 6 differences i found, this took 5 mins, i could easily add many more if i wasnt sat in a mcdonalds carpark.
try explaining how you could overcome these 6 differences without modifying the 1.4 loom and without using the 1.6 connectors. if by some miracle you can explain it, i'll post another half dozen differences.
