are you talking about injectors or coils? your first post is very confusing, which kind of suggests you dont the what they are.
the 20vT injectors can only give you a benefit if you have modifed your enigne so much that it needs more fuel than the stock injectors can give, which would need at least a set of cams, but realistically they would need to be very aggressive cams to require different injectors. if you went for forced induction then you need the 20vT injectors, in all other cases there is no need, you just remap the ecu to increase the fueling on the stock injectors instead, this works better than 20vT injectors.
