Everytime I Corner Fast I Get The Hanbrake Warning Light Come up, just until i have finished the corner! im presuming its my oil level? but could it be anything else? thanks.
oil level ?. I think you mean brake fluid level. maybe you are also cornering so hard all the fluid is going to the side of the reservoir. slow down FFS !
if your fluid is up to the max and it is still doing it then the pad wear indicator wire is probably earthing on something. this wire is only fitted to one front pad on one side, you can remove the wire to stop it happening.
