Hello All,
My Brava 1.9TD100 refuses to start! The 60A glow plug fuse keeps blowing. Does anyone know if the injector/pump is also connected to this fuse? I have tried using 'easy start' spray in the air intake but it seems as if diesel is not getting to the cylinders.
I am thinking that I may disconnect the output from the relay (to the plugs) and then trying again with a new fuse. If there is a short in the plugs/leads then hopefully it would not blow and the motor could start and I could get to the garage.
If anyone has any experience of this, advice would be appreciated,
Darren [this is my first problem with the car in 80k miles!]
