Hi everyone, I just bought a Bravo HLX 115 so I thought I would join this forum and hopefully get some advice that will compensate for my utter lack of technical knowledge.
I dont know if this is a problem or just that im not used to the car yet but when I press the brake pedal there is virtually no resistance (the car does slow slightly) and then it goes rock hard and cant be pressed anymore ( this slows the car down but seems a bit weak). Also when I pump the pedal it makes a hissing sound like air escaping.
Is this normal with Fiat ABS brakes or do I have a problem? All help appriciated.
Cheers, Stuey.
Cheers, Stuey.
