Old 27-06-2004   #1
Brava Intermittent Wipers not working
I'm new to the group, so appologies if this is a repeated thread:
I have recently acquired a 51 reg Brava which I am very pleased with, however it appears to have one small defect: the front windscreen wipers do not have an intermittent setting. It just goes from off to on, then on again (the same), then faster. Also, the wipers just stop in the middle of the screen (ie don't go back to bottom of the window) if you put the wiper stalk back to reset position.
The wipers are still functional, but it's damn anoying if you forget to stop them when they are not at the bottom of the screen! Is this just a fuse, or am i going to need a new relay or something. Any ideas?
Ben
zwyzyk is offline Reply With Quote Quote
Old 27-06-2004   #2
thats nearly allways a dodge columb switch ive changed dozens in the past for the same reason.
-=[uno 1.0ie RAAAWW!]=-
-=[trained fiat tech for what it's worth.]=-
kebab is offline Reply With Quote Quote
Old 27-06-2004   #3
had the same problem. wipers stopped working and clock on radio changed time. just left it for a couple of months and they started working ok
A.BAILIE
FLYFIFER is offline Reply With Quote Quote
Old 28-06-2004   #4
being a 51 plate car its going to have the fiat warrenty still on it, should really get that fixed under warrenty.
Scorg
02 Stilo Dynamic 1.6
Sky Blue
01 Brava 80SX
Ink Black
June 6th 1944
You will not be forgotten
Scorg is offline Reply With Quote Quote
Old 19-10-2004   #5
Re: Brava Intermittent Wipers not working
Just to drag this thread back up again, did anyone ever get a solution for this as I'm having the exact same problem, everything described by Ben is identical to the issues I'm having only this time my cars a 2001 Bravo.
jip is offline Reply With Quote Quote
(T) Rear Window wash not working Scorg Bravo / Brava 5 23-04-2004 04:58
Brava Brava Pictures bravaboy Members Motors 9 12-02-2004 16:37
(S) brava rear spoiler bravaboy Bravo / Brava 1 15-01-2004 03:32
(S) fiat brava bod boyin and lowering bravaboy Bravo / Brava 1 28-12-2003 19:39
(S) fiat brava bad boyin and lowering bravaboy Bravo / Brava 0 09-12-2003 06:54
