jimnewson
Hi Every1!
Ok... i have a 1999 v-reg fiat brava 80sx 1.2 16v.
Firstly i have read many threads regarding this but i 'd appreciate some help with my particular situation.
At the start of December it struggled to start, it turned over and after a while it fired up and i was off. I assumed it was due to the nasty frost that night. However it got worse over the next few days and the turning over was slower and intermittent in the end i had to keep using my dads portable jump starter pack which helped.
I resorted to buying a new battery a the week before xmas and it worked fine, i then went away for a week. On my return the car started fine again so i thought great it was the battery.........2 days later and it wouldn't start. it turned over slowly and painfully as if struggling to breath! so i had to use the the old discovery to get to work! I now think it is safe to assume that the battery didn't need replacing and that it is a starter motor problem???? My father says that is most likely and could be sorted by taking it off and greasing it?????
I am quite savvy when it comes to repairs etc on cars doing a few jobs like brake pads replacing, exhaust front pipe replaced, oil filter and oil renewed and i do have a fairly decent tool range.
I had the car up on the ramps tonight and located the starter motor and as far as i can see there are two bolts mounting the starter motor to the car and there are a few wires connected at two terminals to the solenoid. Is this all there is??? it is quite awkward to access too so do i need to remove some other parts to gain access????
My other worry is that i do not have the red key for my car so if i disconnect the battery to do this work will i need the red key once i have finished and reconnected the battery????
Lastly thank you very much for your patience i know its a bit of a novel but i wanted to be as informative as possible to help you all with any advice.
:bangLEASE HELP!!!!!!!!!!!!!!!!!:bang:
