Recently my bravo 1.4 sx once warm the oil pressure light flashes when the car is idling and goes off as soon as any revs are applied. i recently changed the oil to see if this solves it - even used engine flush to try and clean out the engine. I know 1.4s are prone to oil blockages. Should i change the oil pump or is there anything else i should try first. if it helps the car is sounding a little tappy like the tappets aren't adjusting properly. Please help!!:worship:
