General Where is the airbag Ecu diagnostic socket, Bravo -97?!?
jannen
Anyone knows... need to find it desperately!
I removed the passenger side glove box, all the panels around it, but no trace of of the diagnostic socket.
I need to have the airbag Ecu resetted, the warning light is been on since the stalks were changed. The garage can do the reset, but they or me cant find the diagnostic socket anywhere!!!
Anyone help here? Its 1997 R-reg, apparently its different than 98 or newer ones.:(
there are several different 3 pin connectors, the locations vary according to age and model. usually there are 2 in the engine bay and often one behind the fusebox cover (in front of driver's knee). try any you find, they are all for different modules, abs, airbag, mainbody.
HI all.
I have a problem!!!! I took off all panels, found the ECU unit... theres only ONE yellow cable coming out, going straight to the steering wheel. How do you reset this?!? Theres no socket to do it? DId they mess with something at the factory or theres another way to reset it? ANyone knows?
THanks... I need this despereately!
Try to find if a yellow cable goes behind the glovebox and leads to a 3pin connector and if you dont find it there probably try from the socket that is in the engine bay also 3pin connector.
