Awhile back I had the engine management light coming on. I had a diagnostic done and it returned a fault with the air pressure sensor..i replaced that (€110). Everything was going well until Thursday..the light came on. It started the same thing as it did before..the light comes on and the car sometimes cuts out completely, leaving me with no control. What's the likelihood it is the same pressure sensor? How common with it be for it to go that quickly? I have also noticed a drop in mpg. Are there any tests that I could do to find out if it is the sensor? I took it out today and cleaned it..wasn't dirty and it made no difference! I will have to book it in for another diagnostics during the week..just what i needed!!:bang::bang:
forgot to mention..I checked the oil today and it was almost empty, got quite a shock. I checked it nearly every week..and it never burned any oil..but I hadn't checked it in maybe a month. Could that be connected also? It was serviced 10k ago.
