VolvoV70T5
- Nov 8, 2007
- 19
- 8
Hi All,
Last week I bought my wife a 1996 Brava 1.6 with 55,000 miles on the clock.
It had a faulty injector (number 4 infinite resistance) so I have replaced the whole set and now have 3 good spares.
Before buying the car the owner had spent a fortune on it with a service, new injectors, coil pack etc etc.
I have now just fitted a new gates timing belt kit so it runs smooth and hopefully should be a reliable car (my Volvo T5 is on 225,000 miles so it has a way to go to prove itself LOL)
Anyway, the car runs fine and sounds sweet but when first started when cold if you feather the throttle it revs up reluctantly but if you touch the throttle without being very gentle it hesitates, splutters and even at one point popped inside the manifold
Once the engine is warm it revs up smoothly and is fine.
I know that the ECU system fires the injectors full group when cold and then switches to sequential injection once it has warmed so it seems like the full group firing is over fuelling.
I/She hasn't driven the car yet as the insurance doesn't change over until tomorrow but am just wondering if anyone else has seen this before on the 1.6 engine? My initial instinct is that due to the number 4 injector being dead the long term fuel trims have reached an upper limit and now with 4 injectors firing again and when cold it is massively overfuelling and maybe after a drive the trims will adjust...if not then I will look into it more but it's always useful to get opinions from experienced Fiat owners before making further investigations.
Thanks in advance,
Paul.
Thanks in advance,
Paul.
