FIAT Auto Specialist Team
Old 14-10-2007   #1
1.4 timing belt questions
Have just started changing the timing belt on our brava this weekend and have a few questions i'm hoping you lot could answer for me.
First thing, Got the cam and crankshaft locking tools made by laser. Cam lock fitted on fine, set to TDC...
went to put the crank tool on and it doesn't seem to line up properly, looks like the crank is a tooth out to me as it wont line up with the bolts on the oil pump, what do you reckon?
Taking the fact that it doesn't line up properly away i don't understand how you are meant to get the old belt off, new one on with this tool in place? Haynes just doesn't seem to mention this.
Finally, surely it never came out of the factory with this hole like this?
Looks kinda mangled to me?
R32+Brava is offline Reply With Quote Quote
Old 14-10-2007   #2
faster! FASTER!!!
bulldog5046's Avatar
Trader Rating: 2
bulldog5046 has donated!
Re: 1.4 timing belt questions
never touched a 1.4 12v but personally i would ditch the bottom lock, the crank isnt going to just rotate on its own like the cam will.
no idea about the piece of metal i'm afraid.
Ex Marea Turbo GTi-R owner & BMW Z4 3.0
bulldog5046 is offline Reply With Quote Quote
Old 14-10-2007   #3
fiat_-_bravo has donated!
When I done my belt the tool locked onto the crank no problem.
Lost on therh hole mate.
fiat_-_bravo is offline Reply With Quote Quote
Old 15-10-2007   #4
Thanks for your replies folks. I did think that the bottom lock was somewhat unnecessary. Just seems odd that it doesn't quite line up. Car has lways felt a bit underpowered to me ever since we got it. Am wondering if it has been put together wrongly i past and maybe 1 tooth out or has maybe jumped at some point? Belt is quite worn and slack. I noticed from the off that the crank pulley was slightly anti clockwise past the timing mark when setting the cam.
Think i am gonna take a mark and try hand turning it in both the position it is now and with the crank 1 tooth over.
Old 15-10-2007   #5
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
take the belt off, then fit the new belt, before you tension it get the crank lock in place so you correct the timing. not sure what the hole is but i wouldnt worry about it.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
(G) How many GP's are there on the forum? spacecowboy Grande Punto 379 26-10-2010 22:34
(G) Timing Belt Replacement lightweightmick Panda (Classic) 16 10-09-2010 11:03
