FIAT Auto Specialist Team
Old 12-10-2007   #1
slave cylinder replacement & acceleration probs
Just would like to know how easy it is to replace the slave cylinder on a 1.4 bravo 98 sx, from reading other threads, i think it is located under the battery. Thats as far as my knowledge goes
... aso i was reading a previous thread listed below & I was having similar problems in my 1.4, the light came on & I lost acceleration in the car, it felt like i was driving with the brakes on & had to put my foot down to maintain whatever speed I was comfortably doing before. This problem was intetmitent & still is & when ever I was going to take it to a garage the problem would go & the mechanics could not locate it. I'm just wondering if it is a faulty injector, i think the 1.4 has one but im not sure.
+ my starter motor is sticking as I usually have to give it a few knocks before the engine starts (only recently started happening in the cold weather) Someone mentioned that you could clean it & grease it up to help the situation, would like to know how.
Your help please, Thanks
Originally Posted by dayrox
Ive replaced the plugs and leads and used a lot of redex, but the problem still occurs when accelerating, its become really sluggish recently and i can smell a bad smell of petrol within the car quite often.. =[
its definately time to test the injectors. use a multimeter. the 1.6s are very prone to injector faults.
to measure the resistance of the injectors, disconnect the injector wiring hanress connector. this is at the right hand side of the fuel rail when looking in engine bay. inside the connector there are 5 pins. the centre pin is the earth. touch the black terminal of the multimeter on this pin. the other 4 pins are each for an injector. touch the red terminal of the multimeter on each of these pins, making a note of the resistance for each pin.
each injector should have a resistance between 14.5-15ohms. if any are lower than 13ohms i would replace them.
if you search for posts by me (jug) and search for 'injector' you should find plenty to help you out. you should also find instructions detailing how to change the injector. its very easy.
a scrapyard injector will only cost you a small amount (i usually pay £5 for 1 injector)
make sure you get the correct injector, there are two types- 4hole and 2hole. the best way to make sure you get the correct one is to remove it from an engine exactly like yours. there are 2 different inlet manifolds on top of the 1.6 engines, metal ones on the earlier models and black plastic ones on the later models. you will have metal or plastic so simply make sure its the same on the car you remove an injector from, if it turns out you need one.
lilman777 is offline Reply With Quote Quote
Old 12-10-2007   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: slave cylinder replacement & acceleration probs
you are correct the slave cylinder is underneath the battery. it is attached to the top of the gearbox with 3 bolts, you also need to disconnect the hose that feeds it. replacement is very easy. use a brake bleed kit when you fit the new one to make sure you get all the air out. if you have any doubts a haynes manual is a wise investment.
your intermittent power loss problem should have triggered a fault code to be stored in the ecu, when the light comes on that is usually what happens. a diagnostic should be able to get the code and that will help you identify the problem. since it is intermittent i would think a sensor is the most likely cause, possibly something as simple a dodgy wiring connection or a dirty connector.
a sticking starter motor is more often due to a solenoid fault, you can try to lubricate the solenoid to see if it engages more relibaly, but replacement is the long term solution.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 12-10-2007   #3
Bandido A Maneira!!
Trader Rating: 1
bandido41 has donated!
CTD High Jump Champion
South Africa
Is the 1.4 not a cable operated clutch though?
All the arms we need are for hugging!
bandido41 is offline Reply With Quote Quote
Old 12-10-2007   #4
jug
jug's Avatar
Trader Rating: 1
jug has donated!
some are cable some are hydraulic.
Old 12-10-2007   #5
Bandido A Maneira!!
Trader Rating: 1
South Africa
Quote Originally Posted by jug View Post
Cheers for that jug we learn something new everyday
Old 12-10-2007   #6
Barney, Dennis & Larry
Dobby's Avatar
Dobby has donated!
mines hydraulic. 1998 S reg 1.4 sx
Quote Originally Posted by rallycinq View Post
My dietician advised, 'If it tastes good, spit it out'.
Dobby is offline Reply With Quote Quote
Old 14-10-2007   #7
fiat_-_bravo has donated!
My SX is hydraulic aswell. Never understood why some are hyraulic and some are cable operated.
Or maybe the S has the cable ans the rest of the range are hydraulic?
fiat_-_bravo is offline Reply With Quote Quote
(G) Clutch/slave cylinder replacement antsuno2 Uno 2 22-05-2007 05:55
(G) Panda 0-60 bigdaveakers Panda 13 13-04-2007 19:14
(T) Clutch slave cylinder Kendz Bravo / Brava 13 04-02-2005 13:43
(G) Changed Slave cylinder but can't bleed system!! zeph Tipo (Classic) 2 10-11-2003 23:57
(T) clutch slave cylinder colin w Bravo / Brava 0 20-08-2003 14:29
