Technical hydraulic clutch
brava1.4
West Midlands
Hi guys, my brava 1.4 is fitted with a hydraulic clutch mechanism, looking at the pipe that connects the master and slave cylinders, i was wondering what the device in the middle of the pipe was, any ideas?
I posted the thread about engine mounting, as it had the shudder before i replaced the clutch, and the problem returned a few days after replacing the clutch, as i though it was the problem.
i've never noticed anything between the master and slave cylinders. can you post a pic? a clutch hydraulic fault cant cause your judder. if the hydraulics had a problem you would find it difficult (or impossible) to select all gears.
