Hi all
i have a 97 1.6 bravo which has been giving me a bit of problem recently. I notice that since it has started to go cold, when i start the car in the morning it stutters a lot and idle is very jittery. If i drive off the car dont have much power , but once the car warms up fully, the problem go away, problem is only there when the car is cold or if parked for a long time. I believe that it might be my thermostat because the heating gauge takes a long time to move off the cold mark and also while driving at high speed the engine heat gauge drops to just 1 line above the cold mark. only really reaches half way if doing slow speed like 30-20mph, then will climb to half way mark, which from what i understand is where it should be from start. Also i noticed a leaking radiator, could this be the problem.
I have changed the lamba sensor before and all injectors has been changed before. Lamba sensor was changed because it was burning a lot of fuel.
any ideas where to go with this? Looking to get rid now really, think i will be going japanees or german next car this is my second fiat, had a punto before and did not have no troble with this, but the bravo has been a nightmare.
