Old 30-08-2007   #1
Unhappy Cam Belt Timing
Had a cam belt go on an R reg 1.6 bravo (yes I know I should have checked it - it went before it should have done though in my defence!).
Nearly all sorted now but the problem I have is as the cam belt went I obviously don't have any marks to help with re-aligning all the timing.
What's the best way to sort out the timing not having any marks to align it all up with?
Ta loads in advance!
GavinPearce is offline Reply With Quote Quote
Old 30-08-2007   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Cam Belt Timing
lock both cams using the timing tools and set piston1 to TDC using a rod in the sparkplug hole. it is explained in detail in your haynes manual.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 30-08-2007   #3
Unhappy Re: Cam Belt Timing
Thanks!
Do the timing tools fit on the timing gear or the cam shaft do you know?
And where can you get them from? Any options that are cheaper than Fiat?
The Haynes bible only talks through how to do it if you leave marks prior to taking the belt off, and doesn't really cover otherwise! Unless I'm being blind I guess, but I couldn't find it anywhere ....
many thanks again!
Old 30-08-2007   #4
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Cam Belt Timing
my haynes explains how to use the timing tools, it even has pics to show where they fit on each camshaft. haynes covers both methods, read it again
any motorfactor will sell you the timing tools.
Old 30-08-2007   #5
Re: Cam Belt Timing
Thanks loads!
I'll give it a read when I get home. This forums brilliant, I'll have to stick around here more often!
(G) Timing Belt Replacement lightweightmick Panda (Classic) 16 10-09-2010 12:03
(T) Timing belt / Cam belt? edmundo Punto (Mk2/2b) 5 26-06-2007 17:53
(T) Cam Belt replacement, what else should be done? Kelbert1066 Multipla 0 31-03-2007 19:45
(T) Photo how-to: Marea 20v cam belt change HP Marea 0 01-02-2005 14:20
