Probably a silly question but,
My driverside & passenger side drainage pipes are blocked & I would just like to know where the water is supposed to leave the car, I think someone mentioned that the outlet was under the wheel arches, but I cant see where! I took the driver side panel off to see where the blockage is & squeezed the rubber tubing, which caused the water to come out from the sunroof holes, so it must be blocked further down. The rubber tubing looks like it leads towards the center of the car which I cant get to from inside.
A little help pls
Fiat Bravo 1.4sx R98
A little help pls
