![]() | #1 | ||
Posts: 29 Thanks: 0 Trader Rating: 0 | ![]() Bought a Bravo HGT a while ago and it just doesn't seem to have the power it should. It is an X plate so is the 155 version. I have changed the MAF sensor but hasn't made any difference. Is there anything I should try before going to Fiat. I am planning to check the compression next week, what pressure should I be getting on each cylinder. Thanks.
![]() | #2 |
Posts: 159 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power When was the last service? and what did it have done? Scotty |
![]() | #3 | ||
Posts: 29 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power Was serviced about 2000 miles ago only had oil change etc. Had a cambelt change just before I bought it, car has done 92k.
![]() | #4 |
Posts: 159 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power Mabye a change of leads spark plugs fuel fillter, a good pannel filter would sort it out,if all of the above are getting on a bit they will affect performance Try that first and see how you get on? Scotty ![]() |
![]() | #5 | ||
Posts: 29 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power I have changed the plugs and air filter since the service but no difference. Was thinking of changing the fuel filter as well as carrying out a compression check.
![]() | #6 |
Posts: 1,684 Thanks: 96 Trader Rating: 0 ![]() | Re: Bravo HGT Lacking Power possibly, timing is out.. However first Would do all the normal service procedures, fuel filter etc. Also whack some injector cleaner through the tank and put some high octane fuel in it.
__________________ Ink Black Coupe, ![]() Koni susp' kit, Strut/Subframe bars. Camber bolts, 3g Discs, Yellow pads. Ram air, S.I.P, FMIC, Superspool turbo, Aquamist, Full S/S decat exhaust. Hid's, Le kit and Tan leather. Alfa 156 16v Jtd-m Ti 150bhp http://i54.photobucket.com/albums/g1...2006/alfa1.jpg |
![]() | #7 | ||
Posts: 29 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power Can I check if the timing is out or is it best to take it to Fiat?
![]() | #8 | ||
Posts: 29 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power Checked the compression this evening and have 200 psi on each cylinder. Good result I think. ![]() Spoke to PowerFIAT who suggested I try another MAF sensor as the ones on e-bay can be dodgy. Should of guessed as £40 on e-bay v's £220 from Fiat. Anyone in the Bristol area got a MAF sensor I could try before I fork out some serious cash?
![]() | #9 |
Posts: 4,753 Thanks: 74 Trader Rating: 2 ![]() | Re: Bravo HGT Lacking Power |
![]() | #10 |
Posts: 159 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power ![]() ![]() Scotty |
![]() | #11 |
Bravo 155 HGT ![]() | Re: Bravo HGT Lacking Power ![]() ![]() Scotty where? pm if needed.
__________________ ![]() |
![]() | #12 | ||
Posts: 29 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power Where Scotty?
![]() | #13 |
Posts: 607 Thanks: 2 Trader Rating: 0 ![]() | Re: Bravo HGT Lacking Power get under the car with someone to dab the accelerator and see if the exhaust is leaking anywhere, if it is you will be lossing power though this, Ive had this problem a few times with the cars I owned in the past.
![]() | #14 |
Posts: 159 Thanks: 0 Trader Rating: 0 | Re: Bravo HGT Lacking Power |
![]() | #15 |
![]() | Re: Bravo HGT Lacking Power dont buy an ebay maf, dont buy any maf, just disconnect yours. if you notice the power returns at higher revs it means your maf is the problem, so take it off and carefully clean the hot film. do not use an oil based cleaner, some brake fluid on a clean lint free cloth does the trick nicely. if the problem persists it means you need a new maf, then its scrapyard time for a £10 maf, making sure you get a bosch one. many other cars can supply the maf, inlcuding almost all twinspark alfas. by the way, your compression test result is excellent, it suggests you've got a healthy engine ![]()
__________________ ![]() 2.0 twinspark veloce |
![]() | sammiboo | Bravo / Brava | 255 | 28-02-2008 23:34 |
