Hey
when driving yesterday, i went to pull away from a set of traffic lights when the car suddenly lost power. no matter how far i pressed my foot on the accelerator pedal, the revvs just built up and the car did not increase in speed. it felt as though the car was in neutral, or that i was using the clutch control after a few seconds, the car didnt move at all.
After trying to restart the car (and holding up angry drivers behind) it failed to start, the starter motor did not even engage and attempt to start or even judder. luckily a couple of policemen helped move my car into a safe spot out of the way of traffic.
I then attempted to jump start the car but still no luck. this was the same with bump starting. as the car was parked on a slight hill, i also noticed that the car rolled fowards and was not held back when the leaving it IN GEAR and the handbrake NOT applied.
After a free tow by a kind bloke in a land rover, and a call to a mechanic, he suspects problems with the flywheel and starter motor. there cant be a problem with the gearbox or clutch as surely the car would still start? at first i thought ECU problems but as the car rolls in all gears this suggests a mechanical fault.
in the mechanics words, "the flywheel has shredded and probably shedded its bolts off". apparently the flywheel is connected with the starter motor? and this is why the car would not start.
I will note that the car has not yet been looked over by a mechanic, only me and my dad, all appears fine but we have yet to look at the flywheel. can anybody back up what the mechanic is saying? if he is right, how could this damage of happened? incorrect mounting of starter motor? (it was replaced by fiat 4 months ago).
luckily the car has a 12 month warranty so i shouldnt have to worry about fixing it. just worried about getting it to the fiat dealers as im not with the AA (yet). lol. thank god for my dad and his stilo 1.9 115 JTD towing machine!
my car is a Mk2 Fiat Brava 1.6i 16v
