Hello Everybody!
I am new here in forum( not exactly new i 've been registered from March 2006 But this is the first time i am sending a thread) and i have a problem with my heater! You see i have read all the nearest threads about this problem byt nothing seems like my problem.I am going to be a little meticulous so i am going to apologise!
The problem is when i run the car and the temperature is in the middle of my car i put heat and in the begining i have nice warm air.After couple of kilometres the air starts to going cold!(I forgot to mention that I have 1,2 80 16V 1999 model with climatronic) Lets say the outside weather temp is 15 celcious: I put the heater temp of my car to 23celcious, I have warm air byt after a little the air going colder.I adjust the clima temp to 26 or higher byt nothing.If only i put the clima to position HI the air going HOT and if i put the it to another lower level (ex.26celcious) feels warm byt after a little cold. I manage to figure out myself and i found the problem might be between 2 units. a) The temp potensiometre which i choose temp inside car or b) The mixture electrical actuator(unit that controls the angle of the flap).Does anyone known where is the ECU of the Clima? Is it easy to reach it or i need to unscrew a lot of screws? I need to do some mesaurements!Doen anyone had any similar problem?:bang:
P.S. I have made the diagnostic with display msg "clima err" but i didnt had any fault! The result was 00.
P.S.2 I m sorry for all this encyclopaedia! cheers!
