circolo
Member
I'm in the process of doing this. But found out that the standard alloy bolts on the Bravo are too short for the Coupe 20vt alloys, as the Coupe 20vt alloys have a shallower bolt hole than the Bravo ones.
Luckily, I have a load of old Coupe 20vt bolts, from when I changed the Coupe wheels to Dare V5's. But I'd left them at my workshop in Southend. Got someone to send them up to me over the weekend, so I should be able to fit the Coupe alloys to the Bravo in the next couple of days.
Just thought I'd post this up on here as the Bravo wheel bolts do seem quite short, and I'd have thought would be a problem with most other aftermarket alloys.
Incidentally for the Coupe alloys, you need 30mm long bolts.
