circolo
Member
Is this possible?
My 1.2 80sx 2001 plate wasn't fitted with the optional air-conditioning. It's pretty much perfect in every other way. Comfortable, reliable, good on long journeys, as well as around town. But perfection would be a car that was cool inside, with air conditioning.
Am I right in thinking that on the sx range air-con was an option? Similar to the Punto range, where you had a choice - either air-con, or a sunroof? (Mine has the latter).
If so, is it possible to take the parts off a scrapped Bravo, and install the air-con myself. I know the parts I'll need, as I have this on the Coupe, plus I did some research into this last night. Also, would I need air-con specifically for a 1.2 80sx Bravo, or could I use any scrapped Bravo's air-con?
The other alternative is to buy the parts new from Fiat. But I'd assume the parts would be very expensive - although I could save money by doing the work myself....
As always, all advice is most welcome.
