Is there a difference between an advance actuator and a stop solenoid if so what is it, also owuld a vehicle be fitted with both an advance actuator and stop solenoid or would it just be one of the 2? Thanks all
the advance actuator is another solenoid on a diesel pump, it is used to advance the timing when cold. it is different to a stop solenoid.
your engine can run on fresh air? i think you've just solved the world's fuel crisis!
when you say "i tried disconnecting every single wire i found from the injector pump", obviously you didnt disconnect the fuel pump's live or earth, if you did it would have cut out.
if you disconnect the solenoid's wiring it would not make it cut out, quite the opposite it would mean the solenoid is frozen in position so it cant turn the engine off. a solenoid needs to be connected if you want it to be able to move, it doesnt work using magic, it needs a signal.
all i want is to find a wire that will cut the car out hen disconnected so that i can wire a switch into it so it can pass the mot.
