Get a set of allen keys that yuo can use with a socket then use a power bar works every time!Either that or a long piece of pipe into the back of the allen key save you going to the shop
i have a caliper bolt key (allen key with posh handle) that it strong enough to stick a 3 foot bar on, and then you get enough leverage to crack them off.
as with all bolts that have been seized in by heat, they'll suddenly crack off and then you'll thump something hard with your rapidly moving fist if you arent careful (ouch)
You got the caliper and caliper holder off? The disc won't come off until you have removed the 2x 17mm bolts from behind it. Then you need to stop the disc turning as you remove the 2x 12mm locating bolts. I find sticking a screwdriver through a bolt hole stops it turning
Then if it's still stuck give it a whack with a soft mallet
That's that wheel done, new problemo, other side now, the nut with the weird end on the front of the brake disc will not come out, it's just rounding :'( Any tips??
I've never seen bolts like them before, can they be relpaced with normal flat head ones or will I have to get the same style? And where could I get them?
Or get yourself a little vice - just a 3inch job should do. Clamp it onto what's left of the straight edge and it should make short work of those pesky 12mm bolts.
What are you trying to take them off with? I only ever use a 6 sided long reach socket. 12 sided sockets or ring spanners just mangle them.
They're there to help with aliging the road wheel with the bolt holes. You could use standard bolts or get some from a scrap yard. They're pretty much the same across the whole Fiat range.
This is pissing me off now. Dad is going to get a tool which he thinks will help for tommorow, fingers crossed it will because I have to get it to Stockton by thursday for timing belt!
Can you explain the gridning method? Will that not just leave the centre of the screw inside and impossible to get out?
i mean grind the head off, reomve whaterer the bolt was holding in place, and then get some mole grips on the remaining part of the bolt to get it off.
maybe i misunderstand which bolt you mean, can you post a pic?
thats the bolts i was thinking about. i had to grind one off on a arosa just a few weeks ago, those bolts get very hot, which seizes them in place. if you replace them you should use copper grease, it makes life much easier next time.
