RickyF430
- Oct 17, 2006
- 48
- 9
hi there,
for a while my clutch has been shuddering when pulling away in 1st gear but now it shudders badly and then when i aengage the clutch there is an inital knock then during acceleration the revs increase and there is a loud grinding noise from the clutch similar to the sound you get when you crash gears but has a deeper tone to it.
The car doesnt actually increase in speed when i accelerate despite the revs increasing.
it seems when i hit the torque band of the engine in 1st 2nd or 3rd gear (not as bad in 4th and 5th) the clutch slips and shudders as mentioned above.
The thing that confuses me is when i have the handbrake on and engage the clutch the back of the car squats and the clutch doesnt not grind or shudder so must be gripping! There is no smell of a burning clutch either so im confused.
anyway i just got a quote for a kit replacement (clutch, pressure plate and thrust bearing) -- £232 thats kit labour and V.A.T
the guy must be having a laugh because i can get the kit myself for just £42 and i doubt labour and V.A.T will be that high!
before i commit to anything i wanted to know if anyone has had a similar problem and if it is indeed the clutch itself? I think its more likely the pressure plate or the springs inside the clutch pad itself? but i am not sure what they are called?
any help or advice is appreciated thanks!
