Will this work with the Ipod shuffle? It seems to have a different connection method.Yes you can if you buy the Fiat Ipod interface kit to connect it
I have exactly the same problem. Autoplay seems to do nothing. Hope it's fixed in the next update!
Thanks, I spoke with my Car Dealer and they don't know if in the future there will be an update and it'll work.
Do you know about it?
I don't think that the current generation of Blue&Me will see such an update. Maybe the next generation of Blue&Me. But you know, I'm fine with the way Blue&Me works with Windows Mobile powered phones. Basically every function works, apart from the SMS Reader.
I thought that Blue&Me will have updates and reviews.
1. Press the phone key while parked up, go to settings and then pairing. Your Blue&Me Biatch will tell you to scan on your phone for new devices and then display the pin on your LCD Display. Once your phone finds "Blue&Me" try and pair it and it will ask for the pin just type it in and then its done . It may then try to copy your phone book its hit or miss weither it works or not. Works perfect on my Sony Erricson W800i
2. Yes only files it will play are Mp3 and WMA not dirty Apple format.
Hope that helps
I also need to know if the bluetooth unit is incorporated into the head unit or located elsewhere as my bluetooth functionality has died. Any clues anyone?Anyone on here know about the Blue&Me function? I want to replace the headunit and I'm not sure if the bluetooth mechanism is in the headunit itself, or the same place as the USB connector in the glovebox. If its in the headunit I'll just have to buy a new headunit with bluetooh compatibility, but if know I'ld be able to just hook up a cheaper (but good quality ) headunit.
Managed to get my bluetooth working again by removing and re-inserting all the glovebox fuses.!!!!
I had thought about the battery negative terminal but knowing my luck with this car, was worried that I would do more harm than good. Good to hear it worked for you. I'll perhaps try that myself should the problem return.A couple of days back I got no bluetooth functionality as well and the radio display showed aux instead of media player.
I took it to the dealer where they did a proxy alignment and it was ok for a day. When it got stuck again, I removed the negative terminal from the battery and this seemed to do the work better. It has been a few days now that it is ok...
What is a proxy alignment?
A kind of reset they do with the examiner.
Rebooting the car by cutting the power had minimal negative effects.
I had to reset the date and time..
Trip A and Trib B got reset...
And the media library was rebuilt ( actually this was a good think )
The radio even kept the settings and radio stations.
All the settings in the car's menu were kept.
johnrtaylor I have a RAZR2 v8 and with my car (Alfa 159) does exactly the same thing!!! I've got my car a few days ago and this was driving me crazy! :bang: I tried all sort of workarounds, but no success! Any idea, anyone?Does anybody have any experience of connecting a Motorola RAZR2 V8 to Blue&Me. It pairs up first time no problems, but when I leave the car and get back in it automatically connects then after a few minutes it disconnects and says No Phone, I then have to delete blue&me from the phone and delete all on blue&me then pair up again. This happens I each time I get back in the car. It works fine with a Motorola KRZR.
Thank you.
