How to work sat nav / blue and me
Dom123
Hi all
Just brought a fiat 500c and I have a iPhone 8 phone.
How do I use the phones sat nav with blue and me ?? To come through the speakers whilst listening to the radio is this possible
Hi Dom
I have a similar problem so you are not alone. I used to have an Alfa Romeo Mito 2010 model and that was fine, I now have a Panda Cross and I have tried two different phones - they work fine for phone calls but if I use google maps the phone goes mute. The only way round this I have found (but defeats the point) is to switch off bluetooth on the phone, the phone then unmutes but that is not really the answer. I shall try and google the answer and if I have any joy I'm let you know.
Hi all
Hi again
I have found a work around (for android phones) that might work with iPhone. If you are using google maps go to 'navigation settings' then select 'play voice over blue tooth' and make sure you switch this off. further down on the same page you will see 'play test sound' if you select this while your phone is connected to your car you will hear the sound played from your phone.
I know this is not ideal but at least you can use Google maps whilst driving and have directions from your phones speakers and make calls etc as you should through the cars speakers and listen to radio and mp3 etc.
I hope this is of some use to you.
