im Axle Specialists
Thread Tools
Old 02-10-2008   #1
Unhappy Broken USB port
Last night my girlfriend plugged her iPod cable in to the Blue&Me USB port in my glovebox only to find that the media player displayed (and said) 'No Media'. So I plugged my USB key in, which was working fine 5 minutes prior, and that also had the same message, 'no media'.
After a closer inspection it seems that the metal casing of the USB port is very loose and when a cable/stick is plugged in there is lots of play/movement. I noticed that from a certain angle the USB stick gets power (as the LED lights up on the stick) but this will only be the case for about 1 second or so.
So currently I have, from what I can tell, a broken USB port....
Anybody had anything similar, is there a fix? Can I/should I go to FIAT, will they replace/repair free of charge (even if I have to tell porkies and say it has always never worked?)
Really bummed about this, the girlfriend got a verbal beating!
58 Grande Punto Sporting 1.9 MJet (series 2)
PeteyPye is offline Reply With Quote Quote
Old 02-10-2008   #2
Re: Broken USB port
Turns out I am retarded because I have been using the USB port in the upper right of the glove box which was covered by a blanking plate. I never saw the 'proper' port - which I have now located and confirm all is working.
Now I am still stuck with a broken USB port, blanked out by a bit of plastic now, but I presume it doesn't matter as there is no use for the port?
Thread Tools
USB device drivers - why do they need reinstalling if a different USB port is used? JonnyBoy Computing 12 24-10-2012 04:08
(T) Usb Port! Nik R Grande Punto 20 02-10-2008 20:03
(T) USB Port seannannie Grande Punto 4 28-11-2006 14:54
(G) USB Port Jobling1983 Grande Punto 2 08-10-2006 12:23
