MOT. New tyres, battery, exhaust. Good original example. Family owned since 2000, RED, £1,550 60k
http://www.autotrader.co.uk/classified/advert/201405053930817/
silverstonecars said:Two original keys, Rare panda sisley 4x4, Lots of history,Metallic red, Runs and drives well fun little car. WE OFFER COMPREHENSIVE RAC WARRANTY'S ON ALL CARS -Specialists In Sourcing High Quality Used Cars, £5,000
MOT HISTORY said:Check the MOT history of a vehicle
Registration number: H951THO
- Vehicle make FIAT
- Vehicle model PANDA
- Date first used 8 February 1991
- Fuel type Petrol
- Colour Red
MOT history of this vehicle
- Test date 17 January 2017
- Expiry date 16 January 2018
- Test Result Pass
- Odometer reading 70,942 miles
- MOT test number 6630 8192 4050
- Advisory notice item(s)
Parking brake lever has little reserve travel (3.1.6b)
Exhaust has a minor leak of exhaust gases slight blow front pipe area (7.1.2)
nearside rear Rear wheel bearing has slight play (2.6.2)
- Test date 18 November 2016
- Test Result Fail
- Odometer reading 70,939 miles
- MOT test number 4662 8025 4735
- Reason(s) for failure
nearside front Direction indicator not working (1.4.A.2c)
Exhaust system not adequately supported centre rubber hanger broken (7.1.1)
nearside front lower Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
nearside front Front suspension retaining device ineffective track arm inner bolt loose (2.5.A.4)
engine mounting bracket insecure and likely to fail rear gearbox mount (6.1.D.1b)
Exhaust has a minor leak of exhaust gases slight blow from manifold area (7.1.2)
offside rear Seat belt anchorage prescribed area is corroded but not considered excessive inner sill under (5.2.6)
offside rear Rear wheel bearing has slight play (2.6.2)
- Test date 10 June 2015
- Expiry date 15 June 2016
- Test Result Pass
- Odometer reading 68,910 miles
- MOT test number 3285 0196 5133
Nearside Front suspension ball joint dust cover damaged, but preventing the ingress of dirt (2.4.G.2)
- Test Result Fail
- MOT test number 8887 2176 5129
Nearside Headlamp aim beam image obviously incorrect (1.8.A.1b)
Offside Headlamp aim beam image obviously incorrect (1.8.A.1b)
- Test date 16 June 2014
- Expiry date 15 June 2015
- Test Result Pass
- Odometer reading 60,334 miles
- MOT test number 8366 3776 4107
Nearside Front Brake pipe slightly corroded (3.6.B.2c)
- Test date 5 June 2014
- Test Result Fail
- MOT test number 9360 5605 4150
Offside Lower Front suspension ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
Nearside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
Offside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
Nearside Rear Brake pipe inadequately supported (3.6.B.1)
rear prop shaft(rear uj) slightly worn
- Test date 20 August 2013
- Expiry date 19 August 2014
- Test Result Pass
- Odometer reading 60,295 miles
- MOT test number 2175 6223 3283
Oil leak
- Test date 24 July 2013
- Test Result Fail
- Odometer reading 60,289 miles
- MOT test number 6698 1570 3238
Parking brake: efficiency below requirements (3.7.B.7)
Fuel pipe leaking (7.2.3)
Front Exhaust has a major leak of exhaust gases (7.1.2)
Centre Exhaust system not adequately supported (7.1.1)
Oil leak
- Test date 20 August 2012
- Expiry date 19 August 2013
- Test Result Pass
- Odometer reading 60,262 miles
- MOT test number 5493 2313 2295
under body condition poor
- Test date 1 December 2011
- Test Result Fail
- Odometer reading 60,243 miles
- MOT test number 1857 9553 1390
Nearside Front Direction indicator not working (1.4.A.2c)
Nearside Headlamp aim too low (1.8)
Centre Windscreen wiper does not clear the windscreen effectively (8.2.2)
Front Tyre has ply or cords exposed (4.1.D.1b)
Offside Front Tyre has ply or cords exposed (4.1.D.1b)
Nearside Rear Tyre has ply or cords exposed (4.1.D.1b)
Offside Rear Tyre has ply or cords exposed (4.1.D.1b)
Nearside Front Tyre has ply or cords exposed (4.1.D.1b)
Front Brake pipe excessively corroded (3.6.B.2c)
Offside Front Brake pipe excessively corroded (3.6.B.2c)
Offside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Vehicle structure excessively corroded within 30cm of towbar mounting (6.6.6)
rear brake application uneven (3.7.B.2)
Nearside front brake binding (3.7.B.1)
Nearside rear parking brake recording little or no effort (3.7.B.6a)
Rear Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Looks like it's had it's fair share of welding! Bur has it been done to the required 5K Standards
There was a guy asking about this in the Facebook group a few weeks ago. He felt he got ripped off after buying it from a dealer following seeing how much they bought it for. Looking at the pictures it doesn't seem any thing too special. Certainly not £5k special but may look different in the flesh.
He didn't pay anywhere near £5k for it though did he?! He was on about painting it too so it can't be perfect.
Possibly its just an advertising ploy.
