Panda (Classic) Modified Sisley H671 XYX
Hi Andy,
Im going to presume the shackles have been beefed up for extra height, is there a limit before the rear prop decides enough is enough.
The fronts not been lifted and the plan is to return the back to normal - if I buy it
Only the back has been done? As far as I have been told as long as the alignment of the rear axel and diff to the prop remains the same then you can go upto four inches. ie. the rear axel will have to be tilted backwards over as you lift it higher so that the UJs on the prop don't wear out.
Ask how much longer the shackles are and see if there are any spacers between the rear axel and spring. I haven't really heard of many issues with the rear being lifted it's the front where the main problems lie. PM sent Sam.
